Whats so special about VTEC engines???
118
Ft. Rucker
#21
Rukus,
i think somebody is not getting the message but whatever...
You are 100% right. For people who don't believe the laws of physics, here is another way op proving the point. My friend has a (European model) Honda Civic Type R (200 hp) and his VTEC starts working from 6000 rpm on. Guess what the Dutch Honda site says: max torque is 196 Nm @ 5900 rpm. So VTEC does NOT make the torque come up agressively.
Just my 2 euro cents
#22
I never said it comes up 'aggressively' but if you look at the overall torque curve, it's not that flat.
Show me a dyno chart of a stock vtec engine... and i'll be humbled [:)]
328
Medicine Hat, Alberta, Canada
#24
thats not even displaying a torque curve, thats displaying horsepower. (in the first graph) Its comparing horsepower on 2 different dyno runs.
Of course in a real world, the curve isn't going ot be PEFECTLY flat, come on, get with it, but its going ot be flattest of the flattest.
#25
Okay, I know me saying it was like a mountain was an overstatement.. but it's still not flat
yes, i do realize it's not real world, yes i know it's not going to be perfectly flat, yes I know thats just one type of vtec engine.
I'd like to see the dyno of an s2000, and explained why it has no useable below 4k rpm torque.
#27
I don't understand the discussion here. Honda's VTEC engines are just like most other Japanese engines...not much torque down low, and maximum torque up high. This is not necessarily bad because if you're racing, it really allows you to take advantage of lower gearing. But BMW (and other German manufacturers) give you good torque throughout the rev band for a more enjoyable experience every day.
20
PHX, AZ
#28
I TEST DROVE A S2000 BEFORE MY BMW, THEY ARE FAST YOU CAN FEEL THE VTEC HIT AT ABOUT 6000 RPM AND REDLINE IT AT 9000. THE REV LIMITER SEEMS TO HAVE A DELAY OR SOMETHING BECAUSE THE SALES GUY WAS LETTING REEDLINE IT IN EVERY GEAR I WAS IN AND I MAYBE FELT THE REV LIMITER TWICE BEFORE SHIFTING. I HAD A NON VTEC 2001 CIVIC LX BEFORE MY BMW AND YOU CAN FEEL THE DIFFRENCE BETWEEN THE S2000 WITH THE VTEC AND WITHOUT. STILL I CHOSE MY BEEMER.
681
Chicago, IL
#29
Woe! LOL I created a war among us [eek]. I just wanted to know some facts about the VTEC and I think I have enough already [:p]. Thanks guys but if u guys got something more to add it would be quite nice [thumb]
P.S. Is Double VANOS better than VTEC?
1,129
Milwaukee, WI
#30
I like my VTEC just fine.
I think the original statement about the flat torque curve was more to address the issue that people seem to think VTEC is like an old turbocharger, with an on-off switch. VTEC doesn't really give you a 'boost'. It just extends the ability of the engine to maintain power at higher RPMs, which results in greater horsepower. Horsepower is just torque multiplied by RPM, essentially torque applied to the real world over time.
The S2k is just a 2.0 liter (now 2.2). It only makes about 160 lbs of torque. However, it has the ability to rev to 9000 RPM. It is the ability to rev so high that allows it to make such impressive horsepower. As the RPMs increase, the HP increases (until the engine reaches its maximum power output). VTEC changes the cam profile at higher RPMs so you can run a more aggressive cam profile without compromising low-end driveability and torque.
Think of the engine as an air pump, which it basically is. If you want to move 100 pounds of air in a second, you can do it with 10 gulps in a second of 10 pounds each. You can also move 100 pounds of air with 20 gulps in a second of 5 pounds each. A larger displacement, lower RPM engine takes larger gulps at a slower pace. A smaller displacement, higher RPM engine takes smaller gulps at a faster pace.
That is why the S52(US) M3 engine and the S2K engine both make 240 hp., but the M3 has more torque. Indeed, if you know two engines make the same peak horsepower and you know their respective redlines, you know the one that makes peak horsepower at a lower RPM has more torque.
Horsepower = Torque x RPM/5252. That is why the torque curve and horsepower curve will always intersect at 5252 RPM (assuming the engine can make it to 5252) and horsepower must always exceed torque above 5252 RPM. If you see a graph that says different, it cannot be right. (Like that GSR/SE-R graph). Take a look at the M3 graph below and you will see what I mean. Torque and horsepower must intersect at 5252 if the engine makes peak horsepower above 5252.
If they are both moving 100 pounds of air in a second, they are making the same amount of power. If one car makes 240 hp. from 8400-8500 RPM and another makes 240 hp. from 6400-6500 RPM, the engines have the same performance over that 100 RPM range. The issue of low end versus high end, etc., is not really about the ultimate height of the horsepower curve or torque curve, but about the shape and the overall area under the curve. An engine that makes good power from 5-8k is no better or worse than an engine that makes good power from 4-7k. The issue is more about staying within the powerband, which is why many people like low end power, as it is much easier to stay within the powerband. I think the BMW inline six is a great balance between the two, with a lovely powerband from 4-7k. Still, I chose a car with an even greater powerband from 5-8k.
How that power translates to acceleration depends on a lot of issues, many of which are unrelated to the engine itself (gearing, traction, weight, aerodynamics, etc.)
Isn't this topic really more about 'ricers' than Honda's engineering prowess?
[burnout]
GetFresh.
Banff
#31
Please find some STOCK vtech dyno graphs.
Modified engines have no relevance to this post!
You will find that honda vtec engines (and other manufacturers that use similar systems on their 4cyls) have some of the FLATTEST torque "curves" around. (it's not really a curve, more of a straight horizontal line). This is one of the main things Honda prides about their engines.
I'm not saying they make good torque (oh hell no! it's just a 4cyl with average torque numbers, low for a performance engine for sure!) I'm just saying it's a pretty flat line. Note: saying not asking.
I don't mean to bash you at all, everything else you have stated seems correct, other than the torque curve opinions. Where did you find these strange claims of how a vtec's curve is on the graph?
Hey Rukus, those links are really helpful and explain vtec really well, thanks!
brahtw8, good post as well!
GetFresh.
Banff
#32
#33
Alright, i'm humbled now [:p] Though, the "Max Power = 95.0" thing makes you wander why it was being dynoed. I could see motorcycles having results like that, but not a car.
#34
[burnout]
[cheers] I think, subconsciously, that is part of why i tried to prove it wrong.
I understand horsepower and torque and the relationship to each other, thats kind of useless to post becuase I understand that.. I just assumed ([B)]) that it had a very curvy torque curve becuase they had to be ran in their higher RPM's to have any power. Every review I've read of the smaller vtec engines said that there is no lower end torque. Oh well, not like I'll ever buy a honda anyways.
38
Perth, Western Australia
#36
mmm...very informative...i used to look @ e Integra Type-R as such a great car...but maybe not anymore..
anyways, slightly off track, is VTEC like BMW's Vanos/Double Vanos?
If yes? what is Valvetronic then? or vice versa?
#37
Honda is great at making engines with really great fuel economy and really low emission. I thought that was the big deal about VTEC. Either way, I don't like it when ricers have a huge VTEC sticker at the top of their windshield or something like that. I mean come on, VTEC or no VTEC, 130hp is still 130hp. Hahaha, forgive me, I guess I'm just a hater!
#39
ROFL! Exactly right, MrElussive! When I was in high school and driving my Camaro, ricers used to always brag to me "Well, my car has VTEC." My response was, "Yeah well mine has pushrods and still makes 350 hp. Your's may have VTEC but it still only has 100 some horsepower. VTEC ain't magic!"
"Your Honda has 1.6 liters, and my Mountain Dew has 2.0."
166
Boston MA
#40
EPJ3 has it all messed up again.
VTEC is Honda's answer to low torque small displacement engines. It allows the engine to compensate ignition timing at low revs to increase torque and then give back at the top end. Not for a "MOUNTAIN" type curve like you said EPJ but actually the opposite.. they try for a flat curve.
Honda was the first but Vanos is not any better.
VTEC has been improved with VTECi which is infinitely adjustable.
Honda engines are hardly "economy engines" and lastly, 190 hp in a honda is the same 190 hp in a BMW.
