Ok, so what makes a manual transmission different from an automatic? Is there even an answer to this question? What is a clutch?
Lots of people have been very hateful towards SMG and especially Steptronic. So what makes a transmission manual or automatic?
Does a manual transmission simply have a clutch? And if so, does it matter if it's a foot operated or hydraulically operated one? You could argue that an automatic transmission also has a clutch. Is a viscous fluid clutch not a clutch after all? So you only have a manual if you have a clutch that is operated by your foot? I'm confused. Is it the act of deciding what gear your in or is the act of disengaging a mechanical clutch with your foot? Maybe that's it...
Let me hear your thoughts... I know we probably won't get any definitive answers, but who cares.
-- And for the record, this is what I want to talk about:
Standard 6 speed manual with foot operated mechanical clutch.
SMG 6 speed with a hydraulically operated mechanical clutch.
Steptronic with a viscous fluid clutch (torque converter).
-- Where do you draw the line?
