MrElussive said:
brahtw8, thanks for the response. I love challenging you because you give really great answers and if there's anybody who really knows his shit, it's you.
I guess I can't argue with you there.
Seriously, I don't have all the answers, but I try to at least differentiate between what I know and what I think, and that is why I don't usually get into trouble. If I don't know something, or if I am not sure, I usually will let people know.
MrElussive said:
As for the VQ engine and its torque down low, I am probably just being critical because after having my Jetta 2.slow for a whole year, acceleration has become very important to me. One thing I don't like about the powerband of my car is that the maximum torque is at 4,400rpm and it is kind of a weird experience when I floor it. Let's say that I am driving around and I decide to punch it in 2nd or 3rd gear. I'll watch the tach rising and as soon as I hit mid-4K, the tach just FLIES to redline (6,600rpm)...it is kind of a weird (yet surprisingly fun) experience. I just wish I would get that "push-you-back-in-your-seat" effect that German cars are known for.
Call the below informed speculation or miscelaneous ramblings.
A torque peak of 4400 is not on the low side, but not all that bad either. I think 3500 would be about as low as I would want, assuming a naturally aspirated and high revving engine.
In any event, I would think that you would be getting the push in the back when your car flies to redline from 4500 to 6600.
Torque may not be the relevant number here. I know there has been some discussion about the difference between torque and horsepower before, and which one is the more relevant number, but it may make sense to revisit that a little bit, because in this case I think horsepower may be the issue.
I consider the power curve to be the point from the torque peak to the horsepower peak, with a little bit of RPM before and after, depending upon how flat each power curve is.
If you think about the gearing perspective, take second gear for example, each RPM increment, say 1000 RPM, should translate into the same chunk of MPH. In other words, if 2000-3000 RPM in 2nd goes from 15 to 20 mph, 3000-4000 RPM should go from 20 to 25 MPH.
The reason that you see the tach climb faster from 4500 RPM to 6500 RPM is because the car is making more power such that it is able to cover the corresponding MPH range more quickly than it could from 2500 to 4500 RPM. In other words, the car will go from 20-25 faster than it will from 15-20, in the example above.
If you were able to construct an engine that was otherwise identical to the VQ engine in your G35, but moved the powerband down 1000 RPM, you would get the same result from 3500-5500 RPM that you now get from 4500 to 6500. I don't think it would change your perception of the push in the back.
Frankly, I think that 'weird' feeling you describe is that push, it just is not as abrupt as you are looking for. Perhaps the feeling you want is like having a low torque peak with a large plateau, like a turbo audi or SC/Turbo MB. I think that kind of push is a little more subtle, as it is immediate but very linear. You hit the torque peak and stay on that plateau until you go above the powerband.
Anyways, getting back to the torque/horsepower issue, I think horsepower is the key, but can be deceiving. 240 hp. is 240 hp., but I would consider the S50/S52 US engine in the E36 M3 to be more powerful than the engine in an S2000, despite the fact that both have the same peak horsepower. You need to know the RPM that horsepower peaks at or the peak torque amount to determine which engine is going to make more torque. In other words, if both engines make the same peak horsepower, the engine that achieves peak horsepower at a lower RPM will necessarily have a higher peak torque number (assuming the hp. peak is above 5750 RPM). This is because horsepower is just a function of torque x RPM/5750 (ICBW about the precise RPM, but its close if not correct). In other words, does an engine make high horsepower because it has high torque, or high horsepower because it has high revs.
Again, 240 hp is 240 hp., regardless of RPM, but the ability to maintain a lot of horsepower over a wider RPM range is generally considered a good thing.
I may have gotten off track there, but so be it.
