I have H&R track spacers on my A6 in order to clear larger tires. A full set front and rear, including the extended lug nuts will be around $250.00. It will certainly give you the wider look, and H&R can help guide you on how thick the spacers should be based on your wheel & tire size and the type of car. H&R has a number of distributors around the country. As Pontiac says..."wider is better".
