Only if you stick the sticker on the throttle body, but than your MPG's will actually be cut in half over stock, that is the trade off. However if you stick a sticker on the throttle body and the gas tank you get improved 0-60 and better mileage. (Note: sticking a sticker on your forehead will actually increase brain activity as well......not approved by the FDA, no warranties expressed or implied, sold as is where is, ask your doctor before beginning any sticker program, not endorsed by the forum, close cover before stricking, caution contents may be hot, keep right except when passing, objects in the mirror are closer than they appear, contents under pressure, always wear a seat belt, closed course, professional driver.......and on and on....)
