New to Board...and BMW. Did a search, but didn't find anything useful. Anyone with experience in hardwiring a V1 detector on a '05 or later 530? I'd rather not go the overhead route, but wire to an on/off switchable fuse.
TIA.
Have '07 530i on order. Plan to lease and worried about any installation that will require putting a hole in anything.
I have a C320 MB that I hard wired for a V1 by running the wire beneath the headliner and door piller, undeer the carpet to a free fuse in the trunk fuse box. Not as complicated as it sounds and I can totally remove the setup without leaving a trace.
You should really just take it to a professional shop. If you put holes in a replaceable part, you can always buy that part and put it in when you plan to sell.
