Every 100lbs off is the same as adding 10hp.
Simple to use - just push 2 buttons to get everything you need!
- Push one button for all 4 wheel weights
- Push a second button for all partial %
Heavy duty Red cables and silver AN connectors
15" x 15" low profile pads with 1500 lb. per pad capacity and convenient carrying handles
Roll your car off the scale pads, then back on to release any tire bind or side loads for more consistent readings
All aluminum construction
4 swivel adjusters for quick and easy leveling
Set of 4
2 ramps up for easy roll on and 2 adjustable bridges to connect front and rear scales. Durable, quick to set up, light weight and easy to transport. Adding the optional extra down ramps for a pass-thru system.
Later,
Set of 4
Later,
