Solstice Mallet Details - 400 to 600 hp monster
I'll take the 600 hp supercharged version for $60K!!
BASE PRICE: $37,995 (including $19,995 for the Solstice)
POWERTRAIN: 6.0-liter, 400-hp, 395-lb-ft V8; rwd, five-speed manual
CURB WEIGHT: 3010 lbs
0 TO 60 MPH: 4.2 seconds (mfr.)
The V8 squeezed under the hood of this other-wise benign-looking Solstice is none other than the mighty LS2 sourced from the Chevrolet Corvette. And with almost 500 pounds less heft curbside than the bow-tied beast, the LS2’s 400 horses and 395 lb-ft of torque make for one monstrously fast little roadster.
But lest you think the Mallett Solstice V8 is only about speed, think again: Throw a few cones in front of it and the car really comes to life.
To achieve such superior agility, the car is ballasted such that a 200-pound person sitting behind the wheel gives it perfect 50:50 lateral weight distribution. And with a full tank of gas, the weight split fore and aft is near that, at 52:48.
For the particularly speed hungry, Mallett offers a host of add-ons to pile on the performance, in an a la carte fashion or via additional options packages. The top-end supercharged conversion package, for example, includes a six-speed Tremac transmission with three gear-ratio options; 19-inch alloy wheels and tires; Mallett-Penske double adjustable shocks, coilovers and antiroll bars; transmission and differential coolers; a stainless-steel high-flow exhaust; a 3.73 limited-slip differential; heavy-duty four-core radiator; and a supercharger. That whole shebang turns the Solstice into a screaming 600-hp beast while adding a whopping $38,995 to the price tag of a standard Solstice, which itself starts at less than $20,000
bahnstormer said:
that is a bit short-sighted and bordering ignorant [V]
Hardly. GM designs their cars to do what they do and thats it. The solstice is no different. Stock, it's a GREAT car - I think it looks nice and looks like a fun car to drive. Plus it's priced reasonably.
But no way in hell that chassis was built to withstand that much more engine weight, let alone that much more power. Sorry but no thanks.
equate said:
GM cant build a tranny too :)
I personally dont like replacing my tranny every 30k
What? I've seen a lot of E46's with over 30,000 miles... If there's something they CAN do, its built transmissions.
This company is not new to beefing up Chevys, having offered C5 & C6 'vettes and CTS mods. They are like Alpina or Hartge in that sense. The options include many chassis upgrades, and presumable someone ordering this car would be saavy enough to choose the suspension & drive train options I marked in bold:
# 19 inch Alloy Wheels and Tires
# Mallett-Penske Double Adjustable Shock Upgrade
# Coil-overs (requires Double Adjustable Shocks)
# Transmission and Differential Coolers
# Stainless Steel High-Flow Exhaust
# 3.73 Limited Slip Differential
# Custom Built High Performance Rear Axle Shafts
# Heavy-Duty 4-Core Radiator
# 402cid "Stroker" Engine
# 427cid Engine
# Big Brake Upgrade
# 4-point or 8-point Chassis Stiffener
I think that with these options the car should be pretty solid.
1,343
New York City
Eric has a point there..
But it looks enticing on paper.
# 427cid Engine
# Big Brake Upgrade
Yes, suspension would probably be fine. I'm questioning the structural design of the car. NO company "overbuilds" cars anymore, ESPECIALLY gm. I simply wouldn't trust that chassis with that much power. Even with a "4 point or 8 point chassis stiffener" aka bars between the struts and firewall.
