Ok ease up, I just mentioned some facts, run flats do not perform as well as non-run flats! You than rebuke me with "better email BMW because it was their words" yet you cannot quote the source. Why do you suggest I "support giving advice with a little twist of ignorance"? I can back my position up with fact, can you?
Let me help you Eric, here is a quote defending your psoition on suspension tuning for run flats, "The automakers have also started tuning their suspensions specifically for run-flats. One tweak is relaxing the “durometer,” or stiffness of the suspension bushings, to help cushion impacts that would better absorbed by a conventional tire." (from "The Skinny on Run Flats", Mobil Oil) Notice that therein is some of your lost performance, they are asking the suspension bushings to do some of the old job formally done by your tires.
Also from Mobil Oils web site regarding performance. "All three strategies have their pros and cons. Self-sealing tires don’t require special wheels or reinforced sidewalls, but the lining isn’t foolproof and, if it fails, the car must stop in a safe manner. The tire-within-a-tire lets engineers specify exactly the tire profile they want while assuring that you can still drive after the blowout, but requires a special wheel rim. If you had a set of such tires, those 20-inch chrome wire wheels you have been shopping for are out. The special rim also adds “un-sprung weight,” or weight not supported by the suspension. Gains in un-sprung weight are the worst kind from a vehicle dynamics standpoint, disproportionately affecting the handling and ride."
And Eric, really qouting the media, which media and how would they know???
