Quick Quiz on Tires/Wheels
One of the car mags had several articles on tires and wheels. Here's two questions, who knows the right answers? (If you saw these articles, let the others post some answers first!)
1. If you have a major tire failure/blowout at highway speeds you should:
A. Coast
B. Brake gently
C. Floor it
D. Brake hard
2. Increasing wheel size with an appropriate lower profile tire, provides better handling and performance - True or False?
A. Coast
B. Brake gently
C. Floor it
D. Brake hard
1 - C is correct. Michelin says to floor it to maintain speed until you have control, then gently get off the road safely.
2- True, up to 18"; False for anything bigger. They did a test of various wheel sizes on the same car. Above 18", handling became LESS consistent and stable. The additional weight of the larger rim actually reduced accelleration time and and increased braking distance. Wheels over 18" inches may look good, but that's about it.
This article was in Motor Trend last month.
697
Northern VA
How come race cars have 19" wheels? Well some do, I think?
They were testing street cars, tires and wheels. Several important differences:
- Race car suspension/geometry is designed for larger wheels/lower profile tires. Street car suspension is designed for the wheel size(s) the that were offered by the manufacturer.
- True race car wheels/tires are lighter than any street car wheel/tire. They are designed to be strong for racing stresses (hub, spokes), but are lighter because the rim itself is thinner and lighter. No need to worry about rim strength for potholes, curbs, etc. They also use higher strength, lighter weight alloys to get the job done.
For the test, Michelin has a vehicle rigged with a "blowout on demand" device to pop the tire. They let the reporter try it as they recommended (floor it) but they refused to let him try it with braking. They said their testing proved it was too dangerous!
108
Hastings, MI, USA
Had a rear tire blow on mine on the freeway last summer. Passenger side rear at about 80 mph, car stayed in control fine and I slowed and moved to the right shoulder. All that happened is an (insert your descriptive noun) in a newer Buick Riviera pulled over shortly after me and I asked if he lost a tire, too? Thinking maybe there was something in the road. No, he wanted me to buy him a new front window for throwing stuff at his car and to kick my (insert body part here). Still waiting for the kicking but not loosing sleep over it.
