0-60 mph in 3.9 seconds, 160 mph - so said Autocar in pre-viewing their full road test of the M12 GTO.
Autocar continued, "The M12's standing start acceleration is only just on the comfortable side of sane. If you pay the right money there are faster cars out there. But only a few. But none matches the drama of the M12. At the price the M12 would be considered a fantastic bargain on its sprinting ability alone. And perhaps if that were all there was to it, every other specialist sports car manufacturer with a product hovering around the mid - 40 grand mark could settle down for a solid night's slumber. But the M12 is more than merely quick. Isolate this machines two most crucial tasks, delivering straight - line performance and cornering ability and its difficult to say which it does better.
In short the Noble M12 is blessed with a peach of a chassis. Perhaps this cars most astonishing feature is outright grip. Mechanical grip in the dry is staggering and I have never driven a road car with stronger wet weather adhesion. It truly is astonishing."
Engine
Noble-developed, all alloy Duratec V6 2.5litres. Mounted mid transverse. Four overhead camshafts. Four valves per cylinder. Electronic fuel management. Twin-Garrett, T25 water-cooled turbochargers.
Air to air intercooler.
Max power 310bhp.
Max torque 320lb/ft.
Gearbox
5-speed manual
Brakes
Front: 330 x 30mm ventilated
cross-drilled discs, alloy 4 piston
AP racing calipers.
Rear: 330 x 26mm ventilated cross-drilled discs, alloy 4 piston AP racing calipers. Dual circuit. Servo-assisted. All stainless steel brake lines.
Steering
Rack and pinion 2.5 turns lock to lock Power-assisted.
Wheels
Front: Aluminium alloy 8.5" x 18"
Rear: Aluminium alloy 10" x 18"
Tyres
Front: 225/40 ZR 18
Rear: 265/35 ZR 18
Suspension
Front: Double non equal length wishbone design. Alloy uprights Bilstein dampers.
Rear: Double wishbone. Alloy uprights. Bilstein dampers.
Chassis
Steel space frame with bonded and rivetted alloy panels. Full safety roll cage.
Body
GRP composite with removable front and rear sections.
Weight
Kerb weight approx 980kg.
Dimensions
Length: 161" / 4089mm
Width: 72" / 1828mm
Height: 45" / 1143mm
Wheelbase: 96" / 2438mm
Front track: 59.8" / 1520mm
Rear track: 59" / 1500mm
