Manual transmission noise and rpm?
39
Los Angeles
Hey all,
Why is it that 4,000 rpm in 1st gear makes significantly more noise than 4,000 rpm in say 5th gear? It appears to sound like 1st gear is making the engine rev a lot more than 5th gear but according to the tachometer the rpms are the same for the engine.
It's obvious the 1st gear's gear must spin a great deal faster than the 5th gear's gear considering it is smaller, but is that the cause of the increased rev sound? Also, will cruising at high rpms in a lower gear rather than a higher gear decrease the life of the engine at all or cause more stress/wear on it? Or if not the engine possibly the transmission from more rapidly rotating gears/parts?
Thanks in advance for any information!
