My 1992 M5 has a problem with the battery going flat. The problem seems to originate from the heater control system. A leak down test reveals that the battery is leaking down at .18 amps where it should only be .03 amps at rest. I had a similar problem with a previous m5 and a electrical box had to be replaced somewhere in the vicinity of the micro filter. Can anyone help, why does this problem occur. I have removed fuse no. 20 in the fuse box, this enables me to store the vehicle without the battery leaking down.
