High-Performance Sports Car with Low Fuel Consumption
Presenting the new 911 GT2 at the Frankfurt Motor Show, Porsche is proudly launching the most powerful 911 so far homologated for road use. Through its striking design with large air intakes at the front and the rear wing so characteristic of this very special model, the new 911 GT2 expresses the power and performance potential of the fastest-ever 911 right from the start even at a standstill. Available exclusively with rear-wheel drive and a manual six-speed gearbox, this high-performance athlete accelerates to 60 mph in just 3.6 seconds and reaches a top speed of 204 mph on average fuel consumption of just 12.5 liters/100 km (equal to 22.6 mpg imp) in the New European Driving Cycle (NEDC), thus offering a level of fuel economy regarded as quite impossible in this performance class just a few years ago.
The power unit of the new 911 GT2 is based on the six-cylinder boxer engine of the 911 Turbo, with air supply by two exhaust gas turbochargers featuring variable turbine geometry (VTG). The 3.6-liter boxer engine achieves its maximum output of 530 bhp at 6500 rpm, with maximum torque of 505 lb-ft maintained consistently between 2,200 and 4,500 rpm. With its unladen weight of 3,175 lbs, finally, the 911 GT2 offers a power-to-weight ratio of just 6.00 lbs per horsepower.
The increase in engine power by 50 bhp over the ”regular“ power unit is provided in the new 911 GT2 by two turbochargers with a larger compressor wheel and a flow-optimized turbine housing raising turbocharger pressure to an even higher level. And for the first time Porsche’s engineers have combined the turbocharged engine with an expansion-type intake manifold – a genuine revolution on turbocharged power units.
The expansion intake manifold uses the principle of oscillating air in the intake manifold during the cooler expansion phase, keeping the temperature of the fuel/air mixture lower than in the 911 Turbo. This, in turn, means a significant increase in all-round efficiency, with fuel consumption down by up to 15 per cent under full load despite the increase in engine output.
The 911 GT2 offers new achievements also in terms of emission management and control: This is the first Porsche homologated for the road to feature a rear silencer and tailpipes made of titanium as standard equipment. This expensive material reduces weight by approximately 50 per cent versus a comparable component made of stainless steel to just 20 lb.
The new 911 GT2 comes as standard with PCCB brakes featuring brake discs made of a composite carbon fiber/ceramic compound ensuring maximum stopping power maintained with an extremely high level of consistency. A further advantage is that PCCB brakes reduce the weight of the unsprung masses versus comparable grey cast-iron discs by approximately 44 lb.
Yet another feature fitted as standard is the electronically controlled PASM Porsche Active Suspension Management. (PASM). The GT2 comes on 19-inch light-alloy wheels running at the front on 235/35 ZR19, at the rear on 325/30 ZR19 sports tires.
The new 911 GT2 will be at the dealership in November 2007. The base price of the car in Germany is Euro 159,100.-, the market price including 19 per cent value-added tax Euro 189,496.
http://www.rsportscars.com/eng/cars/911_gt2.asp
