I'm trying to remove the downpipe from the manifold but the bolts are rusted on, and I've already broken 2 studs.
If I remove the rest of the studs by using a dremel... can I remove the head and replace the studs? I'm thinking this might be the only way to do it.
Any REAL help would be appreciated. "check the fuses" won't help.
