Alright, sinceI discovered that my CV joints are fine, I figured out that my Differential is the problem (the grinding/scraping/clicking in slow turns)
I saw that my output seals are bad (leaky) and figured the fulid level would be low -- since the seals are quite obviously leaking. When I took the differential filler bolt, gear lubricant started to drip out!! So it's full.
The thing about the fluid, is that it smelled like a combination of propane and burning rubber - the burning rubber smells was so evident that it almost made me sick (and i'm a guy -- we all love the smell of burning rubber... it was quite bad!!) I read on a chevy truck forum that lubricant from a differential that smells like burnt rubber /propane means it was probably overheated.
What do you think it is? I'm going to drain and refill the differential tomorrow - if the fluid was overheated it could have broken down. Since it's limited slip, I can imagine the clutches inside make it quite hot if pushed enough.
Any suggestions, tips, or thoughts? I dont really have the money to replace a limited slip differential. I wouldnt have a big problem rebuilding it if it came down to it -- but I think the cost will be absurd.
