Do you agree, cross-drilled brakes are "largely a cosmetic touch," "not generally a good idea?" In discussing the new Corvette, Motor Trend says.....
"We asked why the Z51 brakes are cross-drilled, and were told that there's perhaps a slight improvement in cooling of wet brakes, and maybe a bit more initial bite, but the engineers admitted it was largely a cosmetic touch. The aftermarket guys are all doing it, so customers think it's a good thing. Drilling an existing rotor reduces the surface area swept by the pads and removes mass that would otherwise serve as a heat sink in preventing brake fade, so it's not generally a good idea. But the new Z51 brake rotor diameters are larger by 0.6 inch in front and an inch in the rear, and they feature smaller internal cooling vent passages so that their mass is actually increased by 2.2 pounds each in front, 1.8 pound each in back, providing plenty of fade resistance, holes or no holes. And these rotors aren't shaped like a simple hat, with the swept area being the brim, and the place where it bolts to the axle the stovepipe. Rather, the stovepipe and brim are connected by a unique J-section--picture a gutter around the stovepipe. This reduces hot spots and prevents the thermal distortion that results in rotor warpage."
http://motortrend.com/features/performance/112_0408_corvette_tech/index1.html
