I know I have seen this problem on other cars before (not my own), and was curious how to fix it.
I always felt as if the clutch never completely disengaged so I took the car out on a very flat surface, and with the pedal pressed in at idle, when I put the car into first gear it lurches forward a VERY small amount. Now, I know my throwout bearing is going to be bad in a few months - but I also know my slave cylinder could be going bad. The clutch does engage fine with no slipping, but I assume that if the disc were worn down enough, the slave cylinder wouldn't be able to extend far enough to completely disengage the clutch.
Any idea's? I'll be bleeding the clutch this week sometime. If that doesn't help, I'll do the slave cylinder next month when I do the clutch (and lightweight flywheel... )
