I'm interested in Kleen Wheels brake dust shields and was about to order a set but am concerned they may not fit our wheels....they are the 17" 5 double spoke type with the "M" emblem on them(also known as style 68, I believe). What concerns me is what appears to be wheel balance weights on the inside diameter of each wheel where the shields are supposed to be press fitted inside the wheel.....is it possible these are not balance weights but actually part of the wheel? I'm thinking they are probably weights that are glued onto the inner wheel suface rather than crimped onto the front or back side of the wheel rim like you typically see done. I also assume these would prevent the installation of the dust shields unless they were removed. Any thoughts/experience you may have with these shields will be appreciated.
VR
VR
