Brake Calipers Leading or Following?
How come some brake calipers lead, are in front of the wheel and some follow, are in back of the wheel? I have notice this many times on different models. Is any position better than the other?
159
Central, CA
I've wondered about that as well. My guess is that depends on the suspension geometry. A rear caliper would put clockwise torque on the hub assembly, potentially lifting the tire (compress the suspension). A front caliper would do the opposite, and potentially extend the suspension. Throw a little caster in, some weight transfer under braking, and a hard left turn, and the behavior could change.
On most cars, I suspect that front or rear positioning is determined by where the brake caliper can be most easily mounted.
