Thanks, Big Daddy. What I've heard is that vacuum bleeders can draw in air around the brake cylinder cup seals. These seals are meant to work with fluid pressure greater than the outside air pressure. With a vacuum pump, the fluid pressure is below the outside pressure and air can be sucked in around the seals, unless there are cup expanders on. In any case, it sounds like a pressure bleeder is the way to go. Thanks for the advice.
