Hey Everyone,
I am in the middle of installing an amp and subs in my 91 318i. Everything is going fine...almost. There is something going on with the ground connection from the amp. I tried the one dear the battery in the trunk, the metal near the battery...even the negative lead on the battery itself. It only works once in a while. I cleaned the coating of some metal near the battery tray and connected the ground there. It worked great for a few mins, then stopped again. When I connect it to most things that should work...the protect light on the amp goes out but the power doesn't come on...any ideas??
Thanks!
Steve
Thanks!
Steve
