Yes they should fit with no problems, in fact the 225/45-17 is a plus size option for your car. In fact all these sizes are listed as plus sizes for your car:
Plus Zero
215/45-17
215/50-17
225/45-17
235/45-17
225 45 17 is the correct size if you wish to go to a wider tyre. How wide are your wheels? If you are not sure, I would suggest that the wider tyre may look a little chunky on the rim, but the only way to find out is try it.
