Hi all: I have a problem with the fan clutch. It spins fine but the problem is when it revs up to 2500 rpms the fan wobbels and hits the raditor hoses and makes an annoying sound. Some of the blades are broken due to it hitting. What is behind the clutch fan? Could the shaft be bent? Or could it be the fan clutch? Any help would be great. I read the Fan Clutch problems but didn't see anything on this.
The car was hit in the front end and it is possible that the pully might be bent. Is that the water pump behind the fan clutch?
Thanks all.
Thanks all.
